Attempted 3.7.0 update (failed) and now car won't lock or unlock.
2 reading
2.4K views 11 replies 10 participants last post by  RechargeHard
#1 ·
I have a 2022 XC40 Recharge. This morning I got a notification from my app that 3.7.0 was available, so I elected to have it update (battery was at 76%). Some time later I got a message on the app indicating the update failed and that I'd need to take it to a dealer to have it updated and OTA updates would not work until then. Not great.
A few hours after I try to enter the car by handle touch. Nothing. This sometimes happens so I use the fob button. Nothing. This also sometimes happens so I attempt the app. App can't unlock the car.
I use the manual key from the fob and get the driver side door open. All of the lock/unlock buttons in the car are unresponsive. The car works, as in the infotainment center comes up, the car can be put into drive and driven, etc. -- the only thing I know that doesn't work is any means to lock or unlock the doors.
Is this a known issue with a known solution? I've tried rebooting the infotainment system. I have not tried a factory reset but will if that's a known way to fix this issue. Last resort is I drive it to the dealer.
Any tips or help very much appreciated, thanks!
#2 ·
Some additional info:
  • The trunk hatch open button works.
  • The trunk hatch close buttons work.
  • The fob open trunk hatch button works.
  • The app properly recognizes the car is either locked or unlocked after I manually use the physical key to lock or unlock the driver door.
  • When I try to unlock the car via the app the error message says the car cannot unlock the car while the car is in use (it of course is not in use, it is in park with all doors locked and no one inside).
#3 ·
You could try soft-rebooting the TCAM (module that controls all comms/modem/keyfobs/GPS/etc): Hold the FRONT DEFROST button down for 20 seconds, until red SOS light above starts flashing, then wait until flashing stops.
Failing that, you could try a HARD RESET of the TCAM (procedure here: (10) TCAM Reset Process for the C40 - "SOS / eCall Service required" error recovery | Volvo XC40 Forum)
Failing that, drive to dealer.
#4 ·
My 3.7 OTA update also failed in my '23 XC40 Recharge and I had all sorts of issues between the app and the car at first. Besides the reset procedure described above, you may also want to wait it out. My app issues relating to the car status, climate control, and locking all resolved themselves after 24 hours. I was however still required to visit the dealership to complete the update because when an OTA fails, it prevents further updating.
#6 ·
Presumably you've tried a different/spare key fob, and conformed the key fob battery isn't dead? I'd say the fob is working correctly if you're able to drive the car without putting it in the special spot inside the centre console storage bin, but just thought it worth confirming.
#7 ·
Yes, this issue has happened to several owners including me a few years ago.
One solution is to hard reset the vehicle by temporarily disconnecting both the 12v supply and the BuB (TCAM backup battery) for a few minutes.
A sure method to disconnect the 12v is to remove the negative lead to the battery.
The BuB location can be found in the following post:
https://www.xc40forum.com/posts/37258/
If this sounds too difficult to do yourself, just bring it in to get serviced.
#10 ·
I had the dealer do it. So far, a few no rear view camera messages. One black screen, that a restart cured. I am reminded of the British comedy series "The IT Crowd". They hooked up a reel-to-reel tape recorder to their tech support phone line: "Hello, tech support . . . . . . . . . . . . . . . Have you tried turning it off and back on again?" click.
#11 ·
I have a 2022 XC40 Recharge. This morning i .....
Oh gee. I have the same 2022 and need to update as well. I now ONLY do updates after a few weeks have passed.. and when I know I can do without the car for a few days. Mostly they work well.. but two updates previously bricked the car.. no access...no drive..nothing..and both timea needed a flat bed to the dealer... I expect the worst and cross fingers.
But most go well. They had to replace modules both times... i guess the good thing is those modules should be good for a few more years... or until late Dec when the warranty runs out. Glad yours settled in with time. Tick took
R In Toronto
