141 - 153 of 153 Posts
I don't see why not. Their press release includes us:
The new Hakkapeliitta R5 product range comes with a comprehensive selection of over 160 products. Covering sizes from 14 to 22 inches, the Hakkapeliitta R5 is offered in speed categories Q (160km/h), R (170 km/h) and T (190 km/h). Most of the products are marked XL for the highest possible load capacity in that size. The selection will be available to consumers in autumn 2022. The main markets are in the Nordic countries, Russia and North America.
Hi,
I have a XC40 recharge on order in Canada. I also find that having your own wheel and tire set and changing yourself is easier than having it done at a shop.
I am seeing in my area listings for used Jaguar and Austin Martin wheels with the same bore and bolt pattern. They are staggered but a bit wider. Would these work?
9j x 19, 49mm
10j x 19, 46mm
9j x 19, 45mm
10j x 19, 35mm
18" Ford Edge & Lincoln MKX (2015-2022) wheels are the best option I have seen so far.
8Jx18 ET52.5
The offset makes it like stock in the rear and a 3mm spacer will fix the front.
The vehicle's max allowable weight is the same as the recharge so it should be ok.
They are fairly economical & 235/55/18 tires are also priced better.
8Jx18 ET52.5
18 will be tight. Did you confirm they fit?
