61 - 77 of 77 Posts
They are saying its normal vibration from ""the torque converter in lockup mode dependng on the load"
It's not the torque converter. I tested this on mine. Get up to the speed where you have the vibration and put the car in neutral. The vibration will not change. Rev the engine in neutral and it will not change.
Discussion Starter · #62 ·
Ya know.. youre right because I actually forgot I had even tried that before the field tech even came out. So, what are you thinking it is?
Discussion Starter · #63 ·
This was just posted on another forum
Re: Vibrations @55-80mph
Post by Elvo57 » Mon Jun 24, 2019 9:40 am
More inconsistencies….
Wheels swapped with an identical model but with 3,000 more miles on the clock. Drove them back to back with the engineer driving (fault more noticeable in the passenger seat) and the resonance noise stayed with our car. The donor car with our wheels fitted was noticeably better (but still not perfect), hence the mechanic has ruled out wheels/tyres. This he reported back to Volvo and argued with them that the road force balancing (mandated on the 11 point check) would be a waste of time.
End of last week we had the front drive shafts swapped with a new car (destined to be a demonstrator) This was Volvo’s next step in their investigation.
The loan car was an XC40 Momentum FWD, D3 Manual on 18” wheels. The resonance/thrumming noise was still evident in this vehicle, but to a lesser extent (let’s say 1/3 as bad as ours). Our previous loan car was an XC60, D4 R-Design with air suspension and 21” wheels. Overall generally much quieter but spoilt with tyre noise (21” wheels?), clunking suspension over minor bumps (air suspension?) and more wind noise than the XC40 from 60mph (mirrors?). The resonance noise was also there but very distant in the background and had to be really searched for… otherwise it would probably have gone unnoticed.
The new drive shafts made absolutely no difference to the resonance and vibration (just as bad). Technician is now reporting this back to Volvo.
In answer to ChrisLF’s observation on the gear box… the original salesman said that the engines and gearboxes were not shared with any other manufacturer!
The automatic transmission on the XC40 is made by Aisin and is used in many different brands such as BMW, Mini, Landrover, Lexus and Toyota. It may have a Volvo Part number but not a unique transmission - may have programming unique to Volvo however.
I just picked up my XC40 Momentum with 20 inch wheels on April 27. Drove to work on the 29th. Once I reach about 65 mph, I start to feel a vibration in the front of the car and steering wheel. Once I hit 70 mph, it becomes very noticeable. I did confirm with a few other owners in an XC40 Facebook group that they are also experiencing the same issue. They have had their wheels balanced, had alignments, etc and nothing fixed this issue. I spoke with the salesman and he just told me to have service look at it. I just want to know if this is a known issue and if others here are experiencing this. I dont want to have to deal with the service dept not really knowing how to fix it and will file a lemon law claim if this is something that cant be rectified. I really love this car in all aspects except this one annoying issue. Any guidance would be appreciated.
I had the same experience. The tires are shipped from the Volvo factory with foam liners in the tires which may come loose or shift which causes the vibration. Have your dealer remove the liners and rebalance the tires.
Discussion Starter · #67 ·
Tires were road force balanced and all 4 were replaced. Didnt correct the issue. After visiting a 3rd dealer and after they replaced 2 front axles and rotors, they found a defective tire. Replaced two tires. A month after the car driving normally, the vibration reared its ugly head again. I now filed lemon law. Im over Volvo and their garbage customer service and inept service technicians. Pirelli tires are garbage. One of the replacement tires that were sent to the dealer was even defective.
My vibration has been taken care of for now. Went in for my first service and mentioned the problem and my vibrating brake rotors and weird transmission behavior. They rotated the tires since they were off to do the brakes (they did not balance the tires) and they did various software updates. It drives like a different car now and the vibrations are 98% gone. Most people would never notice it.
Super Moderator
So I hate to reopen such an old thread but I believe this is still relevant. I started getting a front end vibration at higher speeds after 20k miles. I'm now at 27k. It's worse on smooth pavement so dealer and I both think it seems like the tires are feathered. That's usually caused by an alignment issue but dealer is saying they see and feel no objective indication that the alignment is off and so wouldn't do one under warranty / Care by Volvo. Just curious if those who were complaining about a high speed vibration last year ultimately found any resolution. I love to drive and am very sensitive to anything being off with the car.. I keep them in great shape for that reason. So this vibration is not something I want to accept.
Weird that the tires they swapped out didnt have the vibration on the car they took them off of though. My issue actually seems worse now. Thanks for the input. I did google vibration issues on those tires and do see what you said. Im just wondering how they are going to put new tires on if they dont even have a road force balancing machine at the dealership...
It’s not the tires, i have the same issue with 18” pirelli pzero, still don’t know the reason. My car was fine and it started having this issue after 7k miles
Try measuring the rotor runout. This looks for concentricity of the hub and rotor. Several issues with each of these parts could contribute to your issue.
We just purchased a 2021 XC40 40 Momentum and experienced steering wheel vibration between 70-79 mph.
Tookit to the dealer and they performed balance including road force balance with no resolution. Finally replaced the propeller shaft and this reduced the vibrations but not completely. Note that the vibrations are not evident when I grove above 80 mph. Prior to having the dealership work on the issue the vibrations were also not as noticeable above 80 mph. Wondering if the resonance has to do with air flow speeds, or if the Perelli tires have an issue at certain speeds.
Has anyone else experience this too?
I have the same issue with my new XC40 (vibrations at high speed). Just wanted to see if your problem has been resolved.
Hi All - I purchased the 2022 XC40 - T5 with 18 inch wheels. Experiencing the same vibration issue reported here at highway speeds. Picked iTunes 1 week ago and I’ve been back to the dealer 1x. They rebalanced the wheels and told me the issue has been resolved. It is definitely not resolved though, still have the vibration.
Definitely wondering how this original post got resolved, if it did at all.
The dealer did the same thing on my car. The vibration has been reduced significantly but there is still a little vibration that is not normal in my opinion. I am waiting to check my car with the new winter tires to see if anything changes.
Super Moderator
I had high speed vibrations and took it to two dealers who told me there was no problem. The third dealer assigned their best tech and he immediately felt it and did a careful job balancing the tires. That solved the problem. He did tell me that the low profile tires (20”) paired with an AWD system will inevitably cause uneven tire wear which is unavoidable. 10k miles later I have really bad road noise and you can hear the uneven wear, but I refuse to change out the tires until the wear indicators show it’s time. The service writer recommended not replacing with Pirrellis when it’s time.
I too have the same problem...XC 40 with 10,000 miles. Took it in to 10k service and told them about the vibrations at speeds over 60. In my case the vibration comes and goes with maybe 10 seconds in between. It is very uncomfortable to drive. Service dept also said it was the tire and they needed to be rotated - which they did..No difference. In fact I think the vibration is worse. Since this is year one in a 3 year lease, I assumed they just didn't want to incur the expense to repair it...and just want til I turn it in and they sell it to some other unfortunate person. I am taking it back in on the 22nd for them to look at it again. But from what I am reading here, there seems to be no consistent fix for this consistent problem everyone is experiencing.
61 - 77 of 77 Posts
