Upon my first charging event after installing v.1.7, I notice that the charging speed is about 5 mi/hr less than before v.1.7. I have always had a 27 mi/hr speed and now it's 22. Has anyone else noticed a reduction?
You need to give us more details on the charging setup. At home? Away? What EVSE are you using? What is the charging amperage readout on the dash?Upon my first charging event after installing v.1.7, I notice that the charging speed is about 5 mi/hr less than before v.1.7. I have always had a 27 mi/hr speed and now it's 22. Has anyone else noticed a reduction?
Correct, reading the speed on the inst. panel. Good thought on the heater. That's a possibility. I will check that next time.I assume that you are reading the speed on the instrument panel display and the car is on. Could it be that your heater is also on using up a portion of the power?
