Unless 1.7 changed something, you should be swiping for the shade and pressing for the sunroof.
Normal behavior is swiping for both, pressing once on the back side just vents the roof. Swiping once will open shade and swiping again will open roof. Can be done in quick succession and both will happen at same time.Unless 1.7 changed something, you should be swiping for the shade and pressing for the sunroof.
1.7 must have changed something, because my roof has the same behavior as OP and it didn’t start until I applied the 1.7 update. Because the switch is still moving the sunshade that implies the software is at fault.Normal behavior is swiping for both, pressing once on the back side just vents the roof. Swiping once will open shade and swiping again will open roof. Can be done in quick succession and both will happen at same time.
LOL. It's all fun and games until little Jimmy gets launched thru the sunroof!I had read they changed the controls. Thanks for working them out. Update notes should really have all the changes since last build in them.
Maybe Volvo is following Apple’s ‘hidden features’ model.
Meanwhile, in a top-secret Volvo laboratory …
Pssst. Looks like nobody has found the hidden eject button yet. What an Easter egg! It took the engineering department months to build it!
Not Google in this case - would be nice, though. My guess is this was an (unsuccessful) attempt to "simplify" things, so as to avoid having separate toggle buttons for the roof and screen (each of which has 3 or 4 different positions, resulting in lots of possible combinations).What was wrong with the old (typical) sunroof controls? Change for the sake of change is stupid. If they did it this way so that Google could control it, then OK I guess, but this feels like a solution in search of a problem.
What car do you have? Gas, hybrid? As far as I know - all of our pure EV model XC40s have the stupid swipe controls, not buttons.So I had this issue as well. Mine has the button not the swipe.
Hope this helps.
Mutter. I still have sunroof anxiety!!! I should probably practice every time I drive !! Stupid swipey crap!!What car do you have? Gas, hybrid? As far as I know - all of our pure EV model XC40s have the stupid swipe controls, not buttons.
I figured it out, hope this works for you also! It’s so stupid that I can’t believe it is even necessary.
In my car I never shut the sunshade, and after the 1.7 update the button swipe didn’t work.
The fix (with the car in Drive so everything is powered up)
1. Hold down the front button so the sunshade fully closes. This is the step I never ever do because I like the open feeling.
2. Swipe to open the sunshade.
3. Swipe and the sunroof should open as normal.
I hope this helps everyone else that has the same issue.
