AFAIK rear camera only is the default. The only way I've ever seen where it will "default" to the 360 camera is if your car's parking sensors happen to be very close to something.When I reverse I can see 360 cameras, and must select manually the rear view camera each time.
Is there a way to set only rear camera automatically when reverse ?
As per my previous reply 360 has been default of my camera / vehicle since I got it. EVERYTIME I back up, no matter where 360 is the default.Your backup camera (alone) should be the default when going in reverse; there is not any (known?) way to make 360 the default. However as others have stated here, the 360 camera will trigger if you have something nearby.
Example: if you park in a garage that has items/obstacles detected on the sides/front of the car, then you may see the 360 camera appear as you go into reverse. This is a precautionary measure that Volvo baked in, for your safety.
To TRULY test this— go into an empty parking lot. Put the car into park. Then go into reverse. You should likely see only the backup camera. that would indicate that indeed the 360 cam is coming on in other instances b/c of obstacle detection.
PS: I find that < 5mph while approaching a few stops signs, in an area with VERY high curbing, our 360 camera appears on our XC40 Recharge. I find it annoying TBH— but I understand the reasoning.
Ha! So true. The acceleration is quite surprisingI suppose hand brake turns will be a thing of the past but back then I couldn't push the gas pedal and get my head plastered to the headrest in an suv either so..tradeoffs I guess.
have you tried an ihu reset? It usually fixes little glitches like this..I have test driven the XC40 recharge in Portugal, and I can confirm that the 360 view is the default there. I have an issue with my 360 view here in the US: the side cameras are dark in 360 view. I can select them individually, and they work fine, but when I go back to 360, they are dark. Any ideas before I take it back to the dealer?
I have not, only had the car for 10 days so just getting to know it. Found instructions, thanks for your help!have you tried an ihu reset? It usually fixes little glitches like this..
nothing will be lost and it’s very easy. Just hold down the home button, the small rectangular button at the bottom of your center screen, hold it down until theVolvo logo appears. You will see screen cleaning mode but keep holding the button until the word Volvo (logo) appears.I have not, only had the car for 10 days so just getting to know it. How do I perform this reset? What will be lost? Sorry, I can likely look this up in the manual...I appreciate your help.
Another good tip to know -- thanks!The dealer found my problem, and I want to share the fix: someone played with my mirrors while the car was parked and they were not in sync. The mirror reset is: hold down the L & R mirror select buttons for a period of time until the whole system clicks and the mirrors reset position. My 360 cameras work perfectly now, and so does the reverse tilt feature.
