This is for the Polestar 2, so maybe we'll get it, too?
Polestar says that tinkering with the 2023 vehicle's software increases the dual-motor Polestar 2's range by 11 miles. That should give the electric hatch an EPA-estimated 260 miles of range. The heat pump included in the Plus Pack now operates over a wider range of temperatures — between 20 and 77 degrees — which helps negate the driving range losses observed in cooler climates. Polestar says the heat pump changes will also be applied via over-the-air (or OTA) update to customer vehicles already equipped with the heat pump.
2023 Polestar 2 EV Can Go Farther and Faster | Edmunds
Polestar isn't taking it easy when it comes to the automaker's only current model, the Polestar 2. Our First Look has the complete list of upgrades.
www.edmunds.com
