so far with 2.9 noticed range under battery percentage and street signs in cluster look refreshed
I see you are marked in the US. Did the OTA get pushed to you here already or did you go to the dealer?so far with 2.9 noticed range under battery percentage and street signs in cluster look refreshed View attachment 6487
Dealer as i had an appointment for regular serviceI see you are marked in the US. Did the OTA get pushed to you here already or did you go to the dealer?
Apple Maps only shows in the drivers display if navigating. If Apple Maps is on the centre screen it’s Google Maps on the drivers display.Thanks for sharing! If you have Apple Maps on your center display, but you are NOT navigating to a destination, does the map appear on the instrument cluster or does it only display the Apple Map there when navigating?
The last picture is interesting - I believe you are using Apple Maps to navigate to a destination (since the instrument cluster shows the instructions) but you have Waze on the center display, correct? I open Waze first, then Apple Maps so that I get the verbal alerts from Waze, such as potholes, speed traps, etc. Best of both worlds.
My 2021 P8 OTAed to 2.7, but I did not see 2.8.Nope. Mine came with 2.6 from dealer new.
2.8 is a dealer only install.My 2021 P8 OTAed to 2.7, but I did not see 2.8.
My thoughts exactly. Way to bring it back.Thanks for posting. It's nice to know that PA/ACC switching via the steering wheel is now back where it used to be. The bullet point makes it sound like a new feature.
The picture in mine matches my car. MY23 XC40 Recharge in Silver Dawn Metallic.This is the screen from my app. 2023 XC40 in Thunder Grey.
I never really had bad charging estimates to be honest. But if so, 2.8 surely fixed it2.8 seems to fix the estimated time to complete charge issue some of you had. We can assume 2.9 will as well.
Well, yes, I do not understand how is possible to write software which gives you estimated time twice faster then theoretical limit. Today, I was on 41%, started charging on 11 kW charger, set to 90%, app said that it will be done in two hours :-D2.8 seems to fix the estimated time to complete charge issue some of you had. We can assume 2.9 will as well.
Can you show screen photo .. about notification? fez foto do aviso de disponivel??Rollout seems to be started here in Brazil.
That says version 2.7 though, it's version 2.9 that should be starting to roll out soon.
Can confirm the same. Estimated completion time is now very, very accurate…. Instead of useless!2.8 seems to fix the estimated time to complete charge issue some of you had. We can assume 2.9 will as well. View attachment 6518
