oh yeah also me! Mine 2023 P6 3500km, It is like knocking sound from front right wheel area… I will see dealer next days maybe same issue!
Thanks André, gonna check that out. I actually think the noise comes mostly from the back so it may very well be due to those pieces.My P6(C40) has 3500kms are back from the front suspension. They'll change something, I don't know what it is yet.
The noise from the rear comes from two black pieces in plastic, that are under the 2nd compartment of the trunk, just lift the carpet and the said plastic pieces are found. One is in the middle of the trunk, next to the central seat, the other on the left side of the trunk.
I running now with another P6(XC40) for 4 days and it's the same....
[/CITAR]
Hi check if the language are ok now in inglish
If you still don't have the car, what are you doing in these forums?
Have they resolved this issue?When I drive my November 2023 (4000km) XC40 P6 over speed bumps there is a sound coming from the front. After extensive searching for the source the dealer found the top bearings of the shocks worn/damaged.
Apparently this is a known issue and a new version of these top bearings are on the way.
Has anyone heard of this before on the XC40? Came across a post on another forum with a guy having driven only 800km’s with his brand new car when the sound appeared.
I used to have the vibration when going high speed (above 160km/h), went to tyre shop and get the balancing done. Then problem solvedi have this since day 1. somewhere from the suspension. sometimes it gets noisier sometimes not so much.
i also have vibration at higher speeds 60mph+ but only for few miles. feels like the vibration from the lane assist getting stuck
