I can't imagine that I'm the only one experiencing this issue. My 2021 P8 vehicle has v2.3 software and it still abuses the 12v battery if I leave it plugged in after the HV charging session has completed. The issue happens only while the temperature is below ~60°F (it works perfectly normal in warmer temperatures). I've mentioned this problem last season where my voltage logger shows the 12v LV battery being unnecessarily drained. Judging by the logs, it seems to be undergoing periodic handshaking with the EVSE. (I notice that my EVSE will blink during that time) . I use the Grizzl-E classic @ 240V/40A, but it also happens with other EVSE's including the Volvo portable one. Keep in mind that HV charging works perfectly. I just don't like having to remember to unlug immediately after charging has completed in order to extend the life of my LV battery.
I just tested it again last night:
The good news is that eventually, when the LV battery crosses below the 12v threshold, the HV battery will automatically start charging the LV battery. I keep hoping for a software fix for the drain issue, but I'm starting to realize that's not going to happen unless I can prove that others are affected by it. If I can't, then I need to convince Volvo to fix my specific OBC unit.
When I read posts about LV batteries going bad, I can't help but think that maybe the vehicle is causing them to prematurely fail. Example:
Software update question… Owner install or take to...
