I'm <1k miles in on my new recharge and the infotainment system keeps crashing turning the speedo and infotainment crazy colours - see attached.
I'm pending a full system replacement to sort it, but in the meantime I've found a fix which stops any crashes.
Use the 'relaxed' driving view rather than the heads up map. On your steering wheel press the button with the two squares (right side, bottom left IIRC). The dashboard view will then be simple directions rather than the full map - this sorts the problem out entirely.
