Thanks for the advice, the issue I have is I am 'old school', I don't use a mobile, I was looking for a simple solution.Import the cds via a computer into your phones app of choice. Then play through the app via Bluetooth.
Neither the USB nor USBC ports read data. One of the biggest disappointments in the Recharge. This has been standard on most base models of any car for over a decade.I’ve read the usbc ports don’t (currently) read data so no way to physically plug it in. You can probably get a Bluetooth adapter for a portable cd player though
Not true, especially for the 2021 XC40 Recharge P8. I have played music off a USB-C stick plugged into the USB-C port with the white circle surrounding it, as I described above. I suspect CarPlay and Android Auto, when they arrive, will utilize the same port for their data magic.Neither the USB nor USBC ports read data. One of the biggest disappointments in the Recharge. This has been standard on most base models of any car for over a decade.
Interesting. What update are you running?Not true, especially for the 2021 XC40 Recharge P8. I have played music off a USB-C stick plugged into the USB-C port with the white circle surrounding it, as I described above. I suspect CarPlay and Android Auto, when they arrive, will utilize the same port for their data magic.
I'm running 1.8. I don't know if it worked with 1.7 - never got around to testing it before 1.8 came along. That said, Android on phones hasn't supported USB Storage Mode for a while. That mode that would let your phone look like a USB Drive. There's no USB mode I can select on my Galaxy S9 that will make the P8 recognize it as a USB stick. However an actual USB-C stick or an old school USB stick connected through a USB-C adapter works fine.Interesting. What update are you running?
Yeah see this is the problem. Now you are talking about a VERY limited way to make the USB 2.0 "work" in the Android system.I'm running 1.8. I don't know if it worked with 1.7 - never got around to testing it before 1.8 came along. That said, Android on phones hasn't supported USB Storage Mode for a while. That mode that would let your phone look like a USB Drive. There's no USB mode I can select on my Galaxy S9 that will make the P8 recognize it as a USB stick.
Well, it's too bad it doesn't work the way you want it to, but that doesn't mean it doesn't work.Yeah see this is the problem. Now you are talking about a VERY limited way to make the USB 2.0 "work" in the Android system.
People have iPhones- they have normal needs. Now we need to do "USB Storage Mode" on an Android phone to make the car see it? Are there instructions that come with the car?
No.
The problem is the XC40 cannot recognize phones or play data from devices in the "normal" way.
ie: I plug in my phone- it plays.
We have an fm ratio?Every once in a while I have a moment when I am reminded I’ve got some years on me. When my dad brought home our first car with a cassette tape player, I sat in the garage for hours playing with it, the power windows and door locks. Even before that, though, it was so exciting when we picked up our first car with an FM (vs. AM only) radio. I guess things can change pretty fast… I’m not that old!
Anway, to answer the original poster, you used to be able to buy a very inexpensive and small FM transmitter that would plug Into the headphone jack of a portable CD player. You could then broadcast your CD to the FM radio in your car. You had to have that thing pretty close to the radio for it to sound halfway decent, but it did work. Not sure if they’re still sold today but I bet they are.
Yes. Not sure how it's implemented hardware wise, but swipe right on the media bar to select the radio.We have an fm ratio?
