Every vehicle I've owned for the past 15+ years leaves the vehicle lights on for some period of time (30,60 seconds, whatever) AFTER you lock the car, just as an added safety measure. I happen to park in a relatively dark area, so this feature is actually useful to me. However, the XC40 shuts down all the lights as soon as I lock it. There is a mention in the owner's manual that you can manually activate guidance lighting when you park by pushing the left stalk back before you exit the car. That's not working for me - once I park the car, and even press the Park button, then push back the stalk, all it does is flash the high beams. No Guidance Lighting is activated - no icon shows in the display to indicate that. But, more importantly, why should I need to manually activate it?
If this is something that is unique to the Recharge, I suppose I can see this as a battery-saving feature, but even then, I would expect a settings option to enable/disable it. Have I missed a setting somewhere?
PS: I do realize the lights stay on after I leave the vehicle and that I could walk away and use my fob to lock it, rather than touching the door handle. Just doesn't make much sense to me that this is required.
