My garage was wired for a Blink EVSE back in 2011 for my new Leaf. The Blink was on the right side which was fine for the Leaf and much easier to install because of the workbench and washer/dryer on the left. Now with the 240V socket on the wrong side for Volvo, I have to back in to charge. Technically I can do it when facing forward if I pull in way on the right side, but only at risk of scratching up the paint on the roof of the car dragging the heavy cable over the top. The problem is that it's a tight fit. If I pull in too far, I cut off access from the house to the wash/dryer workbench area and if not far enough the garage door will come down on the car. Also, there's lots of stuff on both sides that causes the warning system to sound alarms at me as I back in, and visibility isn't good coming from the bright sun to the dark garage, especially with sunglasses on. My solution was to paint stripes on the floor of the garage so that the camera system recognizes the stripes and stops screaming at me as I back in. I've tested it pulling in forward and the bird's-eye view camera system sees it perfectly and I can place the car perfectly. I haven't tried it backing in yet, but if nothing else, it will make it easier for me to judge my positioning. I don't expect others here will need to do it, but I'm rather proud I thought of it. My butt is still sore from all the squatting. I used masking tape, spray paint, and a sort of stencil made from a cardboard box.
