Hello everyone, wanted to share my experiences and data i collected on my Ohio - Denver - Ohio road trip i took. First, the data! Hopefully i collected the important info, and i did my math right lol. Almost all of my charging was done with Electrify America, unless it was free at hotels, or i called out in the notes if it was ChargePoint. Total miles for the trip was around 2,850.
Couple important notes:
Overall, the trip went great, and the the XC40 was super comfortable to road trip in. Mechanical wise, I didn't run into any issues outside of apparently getting a nail in one of my tires (unrepairable, and ordered a new rear set). Thankfully the tire is holding up fine outside of adding air every few days. I didn't have too much range/charging anxiety during the trip until I got past Kansas City. After that, you basically have to stop at every charger along the way, and there are no real DCFC alternatives if those are not working. Range estimates were for the most part, pretty accurate, typically leaning towards the more conservative side. There were a couple instances where the estimated arrival SOC and actual arrival SOC was off by a large amount, and once instance when doing the math in my head, and knowing what my actual consumption was, i didn't think i could make it to the next planned charging stop and manually added an additional stop. So in summary:
And some pictures!
- These were all taken while running software version 1.7, UNTIL 12/9. I updated to 1.8 while at my hotel the night of 12/8.
- I planned my trip with ABRP, but used the car navigation so that it would pre-heat the battery. The charging stops it added aligned with what i had in ABRP with 2 exceptions on 11/30 and 12/9.
- Doing long road trips in an EV are doable, but you do want to do some planning ahead of time and have alternative stops in case there are issues
- Based on the weather (wind, temp, etc) and speed, i don't think i would get more than about 160ish miles out of a charge (100% to 10% SOC). you might be able to squeeze more out, but if you mis-calculate, drive too fast, or have a strong headwind, you could end up in trouble
- By and large, the range estimates that Google provides are usually pretty close, and i usually ended up arriving with more SOC than what it estimated. Problem is there are a couple instances when i arrived with less, so that again comes down to planning.
- I was being overly cautious with my arrival SOC, and purposefully charged longer than i needed to. With the lack of available DCFC in some areas, i wanted to be extra safe than sorry.
And some pictures!
