1 - 4 of 4 Posts
If you have the symptoms as described then you're low on coolant. It can happen if there was a little bit of air trapped in the system. Your fix will be just to fill it up. It's very simple but you have to go to the dealership 100%.
Went to the dealer, they couldn’t see any codes, did a pressure test and found no leaks, and saw that coolant wasn’t low at all…so sure what’s next.
Hm...Coolant level is not the case. Seems like software glitch. Strangest thing is the lack of error codes.
Drive longer and prosper :)
1 - 4 of 4 Posts
