Hi All
Currently, on the recharge, you can set the following parameters for charging on the vehicle
with the default charging profile of 90% and 20A even if I go to a fast charger the car will only charge at this limited rate and I have to go into the settings and change it to fast charge and then again update it when I get home....
any recommendation or insight into a software update that will support multiple charging profiles?
- Limit in %, (i have mine at 90%) what is the recommendation to keep this at 80% and then increase it before a long trip?
- current limit I have mine at 20A 220 VAC as this is the limit of the socket/ wiring I have in place.
