Have others noticed a good deal of brake odor? I never overuse or "ride" the brakes, but I often smell hot brake odor. No warning lights are on. Also, is it normal to have to tap the gas to disengage the parking brake?
Thank for explaining the nuances of these features. i think the Owner's Manual is silent on the fine points of much of the car. I am really beginning to hate this car. It's like being tortured my having to use a PC again.The brakes will fully release when the car is in gear and Auto Hold is switched off. With Auto Hold on, the brakes will remain set at a stop until the gas pedal is depressed. This is a matter of personal preference. You can toggle Auto Hold on and off as I described with the button on the tunnel console. I think the issue of the engine shutting down at a stop is an independent feature called Auto Start/Stop. It operates somewhat in tandem with the brake Auto Hold when both are activated. It causes the engine to shut down at a full stop under certain conditions, to save fuel. The engine will automatically restart upon lifting your foot from the brake or, if brake Auto Hold is activated, upon depressing the gas pedal. The engine Auto Start/Stop feature can be toggled on and off from your center display function view. There is a rectangular button for that. Sorry your dealer didn’t demostrare these features to you upon delivery. They do, in fact, represent modern safety and fuel efficiency technology, but there absolutely is a learning/comfort curve. Hope this helps.
