I installed one of these guys in the cargo area of my Outback for running my Dometic Fridge and other junk while camping/running around on road trips. In that case I ran a 8ga wire direct from the battery through a separate fuse box and to the rear of the car.
I'd still fuse it at 10A, but using larger gauge wire to avoid the voltage drop near the top end ... and of course having it be live all the time which is the real goal. I've seen a few posts on dash cam installs (which I may do also) but being such low power consumption I cant see a reason not to tap into almost any circuit for that.
I'm pondering doing the same thing with my '21-XC40 and debating between a similar approach or utilizing an empty fuse position in the fuse box under the driver seat. Wondering if anyone has any first-hand experience with either approach.
Thanks!
Thanks!
Amazon.com: Electop 12V USB Outlet Socket Panel, Waterproof Cigarette Lighter Socket Dual USB Car Charger 2.1A & 2.1A with LED Voltmeter, 12 Volt Power Socket Adapter DIY Kit for Car Boat Marine Motorcycle RV : Automotive
Buy Electop 12V USB Outlet Socket Panel, Waterproof Cigarette Lighter Socket Dual USB Car Charger 2.1A & 2.1A with LED Voltmeter, 12 Volt Power Socket Adapter DIY Kit for Car Boat Marine Motorcycle RV: Cigarette Lighters & Parts - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
