I'm trying to figure out what wheel options might be out there. For reference, here are the specs I can find for the OEM P8 wheels:
PCD 5x108
63.4 hub
OEM 19
19" x 7.5" 50.5mm
19" x 8.5" 56mm
OEM 20
20" x 8" 50.5mm (same vs. 19")
20" x 9" 58.5mm (inner 2.5 mm less clearance vs. 19")
One contender is the OEM Polestar 2 19" wheels. Here are their specs:
Polestar 2
OEM 5-V 19" black diamond cut 31680895, 32134523
19" x 8" 50mm (match for P8 OEM 20")
19" x 9" 53mm (extend +3mm vs. P8 OEM 19", extend +5.5mm vs P8 OEM 20")
The new Polestar 19" wheel part numbers are 32327781 (front) and 32327782 (rear).
So the rears would extend (poke) an additional 6mm vs. the OEM 20" P8 setup. Can anyone with the 20" option take a look at the rear wheel well and see if this looks reasonable? If so, the Polestar OEMs could be a good contender for a winter set, as they can be found for around $350/each.
I'll update this post if we can find any other good contenders.
PCD 5x108
63.4 hub
OEM 19
19" x 7.5" 50.5mm
19" x 8.5" 56mm
OEM 20
Polestar 2
